Thread: Icbm-digital 2 channel |
Bronze Member Username: Blindmp2
Post Number: 14 Registered: Feb-05
| Posted on Wednesday, March 02, 2005 - 08:12 pm: |
i have a icbm-digital two channel amp, and i have 2 subwoofers, dual 4 ohm, im wondering if i could bridge the woofers to get 1 ohm but im not sure if the amp can be brigded |
Bronze Member Username: Kojak28
Augusta,
GA
Post Number: 43 Registered: Feb-05
| Posted on Wednesday, March 02, 2005 - 08:51 pm: |
Do you have the box or model number of the amp? Really a mono block is going to work better, MOst are at least 2 ohm stable. Many are 1 ohm stable. |
Post Number: 16 Registered: Feb-05
| Posted on Wednesday, March 02, 2005 - 09:05 pm: |
this is one ohm stable |
Augusta,
GA
Post Number: 44 Registered: Feb-05
| Posted on Thursday, March 03, 2005 - 05:45 pm: |
Mono block amps are already bridged onto 1 channel(MONO BLOCK- mono means one) Do you mean you have 2 speaker outputs on the amp? |
Post Number: 24 Registered: Feb-05
| Posted on Friday, March 04, 2005 - 02:17 am: |
yes i do |
Augusta,
GA
Post Number: 47 Registered: Feb-05
| Posted on Friday, March 04, 2005 - 10:10 pm: |
That amp is very similar to my own (autotek sx1200-x) It also has ONE speaker output Split into TWO. You want a 1 ohm load to the amp right? Do this: Wire one sub's voice coil to the other (neg-neg, pos-pos) then wire it to ONE speaker outlet(neg-neg, pos-pos). Do the same with the other sub on the OTHER speaker outlet. This should be 1ohm at the amp. Correct if I am wrong here guys. Kojak. |
Post Number: 27 Registered: Feb-05
| Posted on Friday, March 04, 2005 - 10:37 pm: |
you are correct in getting 1 ohm, but im not sure, if the amp doesnt say brigde wont it hurt it |
Augusta,
GA
Post Number: 52 Registered: Feb-05
| Posted on Saturday, March 05, 2005 - 11:42 pm: |
The definition of bridge is (in car audio lingo) is: putting 2 channels and making 1 out of them. Mono blocks are already "bridged" internally. L & R channels are converted into 1 within the amp. Wire it like I said previously & check it w/ the gains set low. By the way what is the rms of that amp @1ohm? |
