Home > Message Board > Car Audio > Amplifiers > Archive through March 04, 2005 > Audiobahn A8000T - This is a serious ...
Author Thread: Audiobahn A8000T - This is a serious post!
Username: Tdbdrummer
Post Number: 51
Hey, I am looking at this amp, and was wondering if it would be a good investment to pick up 2 of them off of Ebay ($150 each), and run each of my Volfenhag subs to them? Well, 1 sub per amp! If anyone sees as to how this is a bad investment TELL ME! If anyone has any experience with this amp TELL ME! Lol ok, that's enough for now!
Username: Taylor17
Kopperl, Texas
Post Number: 799
The amp is pretty good. Don't know about the price, could be good, don't really no. Isaac really like's them, so they can't be that bad. I also like Audiobahns amps.
Username: Subfanatic
Walton, Ky
Post Number: 711
they are 200 dollers normally
Username: Wojopro
Silverdale, WA
Post Number: 198
I was waiting for the punch line... Hehehe
Username: Sublime420
Ca
Us
Post Number: 112
Audiobahn sux.
Username: Carguy
Post Number: 1664
I have tested Audiobahn's Intake series amp. It is good for the money. The cheapest I've seen on eBay was $130. You might want to shop around.
I think you sould try 1 amp first. Not like your sub is power hungry.
Post Number: 61
Ok, ok PICK ON THE VOLFENHAGS lol!
Post Number: 63
At Circuit City they are like 350 each, so I thought I was getting a good deal.
Username: Carguy
Post Number: 1675
$350? Are you kidding? That is some ripoff. Not as bad as Futureshop or Bestbuy in Canada. They take $340 amp and charge $899.
Post Number: 65
Wow...they need to die...
Username: Hdubb
Farmington, Nm
Usa
Post Number: 1013
i didnt like mine, it didnt last long, and it didnt seem that it was doing anything close to 800 watts
Post Number: 66
Well Hunter, I'm sorry but I just don't have the kind of money to buy one of those Zapco, Arc, US, JBL, or any other crazy priced amp. Anyone know anything about Lanzar Heritage 2000W mono amp?
Post Number: 67
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5756688272 %26%26
NOW THAT's MY KIND OF PRICE *DROOLS OVER SELF*! If only I had the money right now, that thing would be here in a jiffy!
Post Number: 68
Holy mothers...they have a JBL GOT 1201.1 for 285! NEED MONEY LOL!
Username: Carguy
Post Number: 1696
Lanzar? Stay away from those suckers. If money is a problem, then look at PPI's PC/PCX series amp. Lot of them are priced under $200, but very good amp.
Post Number: 72
Ok. What about those JBL's and their prices? Good amps? Good prices?
Username: James1115
Wilton, Ct
Post Number: 1538
go wiht the PPI's like Isaac said try to stay away from class d if you can. You will appreciate the sound much more trust me:-)
Post Number: 73
I still want mono though right?
Post Number: 74
Um, I looked at the PPI's and they are almost 400 bucks for 1000W. And 250 for 500W. Wouldn't I need at least and 800W amp as to not underpower? the two subs? even at 2 ohms its only 500W MAX. That could be a problem. I dunno, I may go with the JBL for that reason.
Username: Hdubb
Farmington, Nm
Usa
Post Number: 1043
if you go lanzar ONLY the opti2000.
Post Number: 75
That Lanzar seems nice, but its hard to believe I can get close to 2000W for only 300 bucks. How true are its ratings?
Username: Hdubb
Farmington, Nm
Usa
Post Number: 1045
honestly i think that they are pretty damn close, isaac going to ream me but i think that that amp is nice. it can go down to 1/2 an ohm.
Username: Invain
Michigan
United States
Post Number: 1290
Lol. I wonder how long it can honestly run at that .5 ohm?
Username: Invain
Michigan
United States
Post Number: 1291
Probably need an air conditioner sitting next to it.
Post Number: 77
Well, I prolly won't have past 2 ohms.
Username: James1115
Wilton, Ct
Post Number: 1553
hey TB what are the specs on those subs?
Username: Carguy
Post Number: 1702
Whenever you doubt some manufacturer's spec, use $1 per 1w terminology. I find that is a true measure of real power. Use PPI's white Art series amp. The 600.2 is 600w rms amp, and it sold for $699 several years ago. Now you take Pyramid/Sony/Lanzar's 1000w, $200 amp and compare. If you actually take the time to test the amp, you'd notice that half away up the volume, the amp will over heat and distort/clip. This is what kills most subs and speakers. Yes the amps are cheap, but is it worth burning out your precious subs slowly?
Some manufacturers do tell half truth when they say 1000w. You might get that under extreme conditions, but notice they never say "clean" power. That is what you're really paying with great amps. True, clean useable power.
Another thing, 1000w from those amps and 1000w from a real amp will sound totally different.
Test one out and you'll understand.
Post Number: 79
James, the specs on the subs are 500W RMS, and 1000W MAX. Isaac, so would I better off with one of the JBL GTO 1201.1 amps compared to the Lanzar? The JBL is still within my price range and I'm sure would give me plenty of power.
Post Number: 80
I have two of the subs btw, in a sealed box. Not as efficient, but nicer rolloff.
Username: James1115
Wilton, Ct
Post Number: 1580
what is the voice coil configuration?
Username: Carguy
Post Number: 1707
A choice between Lanzar and JBL, it's JBL.
Post Number: 81
James, the voice coil config. is dual 4 ohm.
Home > Message Board > Car Audio > Amplifiers > Archive through March 04, 2005 > Audiobahn A8000T - This is a serious ... [ « Previous ] [ Next » ]
