Home > Message Board > Car Audio > Amplifiers > Archive through March 04, 2005 > Mono amps?!
Author Thread: Mono amps?!
Username: Hiphopanonymous
Post Number: 173
I have a mono amp mtx 6500d. it has two out puts like
+- +- . Now do i bridge these two outputs? or do i just use one output for a sub? I have never had a mono amp before. Only been using 2 channel amps bridged. any help would be appreciated.
Username: Nnnnick_b
Nc
Usa
Post Number: 157
the reason there are 2 outputs (+ - , + -)
is for ease of use. U dont have to try and jam all the speaker wire into one hole. It is acctually just one output split into two.
Username: Tdbdrummer
Post Number: 23
It turns the stereo signal into a mono signal!
Username: Kojak28
Augusta, GA
Post Number: 35
On most mono block amps, the signal is converted internally to MONO. Nick is right-one speaker outlet---split into 2.
Post Number: 175
ok cool. that makes sense. thanks.
Username: Kojak28
Augusta, GA
Post Number: 39
How many subs you runnin? Just curious
Post Number: 176
i'm runnin 3 10's that are all wired down to 4 ohms. i could wire it all to 1 ohm but the mtx only goes down to 2 ohm stable.
Home > Message Board > Car Audio > Amplifiers > Archive through March 04, 2005 > Mono amps?! [ « Previous ] [ Next » ]
