Thread: Are these subs any good |
zackrude Unregistered guest |
| Posted on Monday, February 28, 2005 - 11:56 pm: |
http://www.fortunecity.com/skyscraper/black/438/rf/rfp2810.html for a 10" sealed box in a truck |
Bronze Member Username: Tragedy
San Jose,
CA
Post Number: 23 Registered: Feb-05
| Posted on Tuesday, March 01, 2005 - 02:49 am: |
Good in what sense? The sub is 8 ohms with a nominal power rating of 200rms. Generally the higher ohm subs are paired with 2-4 subwoofers to lower impedances but i think this one is a single voice coil so running one only would require a bigger amplifier to push 200rms at 8ohms. Amplifiers dont show 8ohm ratings so if your stuck on this sub look for an amp that pushes 400-500rms at 4ohm. Look for a dual 4ohm subwoofer, i think that would be your best bet. Kicker Comp VR is always a great low-budget choice. |
| Posted on Tuesday, March 01, 2005 - 10:05 am: |
would they sound good in a 10"sub sealed box in the back of my truck thanks |
San Jose,
CA
Post Number: 28 Registered: Feb-05
| Posted on Tuesday, March 01, 2005 - 11:19 am: |
I am sure for what you are after they will be fine. I had a RF HX2 10" in a ford ranger with a compact size enclosure behind the drivers seat. Sounded good inside the cabin, but outside the truck the bass wasnt to great. Depends what your after. |
