Thread: Rear Speakers? |
| Posted on Monday, February 28, 2005 - 05:46 pm: |
I've heard a lot of negative remarks about having rear speakers. I just bought a pair of Diamond Audio s600s Component speakers for the front and I would like to know if i should buy a set of rear speakers. I'm not getting any subwoofers, but i still want some bass. I thought a nice set of mid-bass speakers would be nice for the rear. Are the rear speakers necessary? |
Silver Member Username: Xxkmfdmxx
St. Petersburg,
FL
Post Number: 394 Registered: Oct-04
| Posted on Monday, February 28, 2005 - 07:30 pm: |
If your not getting subs then I'd go with rears..Either way I would go with rears. Sounds better if ya ask me. |
Silver Member Username: Nnnnick_b
Nc
Usa
Post Number: 112 Registered: Jan-05
| Posted on Monday, February 28, 2005 - 09:24 pm: |
Many people dont like rear fill. If u do put in rear speakers try crossing them over(cut out the highs) This way they wont distract from your front stage. U can do this with many HU's |
Bronze Member Username: Sanchez5888
Post Number: 32 Registered: Dec-04
| Posted on Sunday, March 06, 2005 - 11:39 pm: |
Personally I think you should definitely have rear speakers. They create a fuller sound in the car in my opinion. Sure you can spend hours or hundreds of dollars trying to set your front speakers just right and not use rear speakers. Or you could just put in some rear speakers and it all fills in together very nicely |
Gold Member Username: Jonathan_f
GA
Post Number: 3441 Registered: May-04
| Posted on Sunday, March 06, 2005 - 11:55 pm: |
"Sure you can spend hours or hundreds of dollars trying to set your front speakers just right and not use rear speakers. Or you could just put in some rear speakers and it all fills in together very nicely" Until you hear a system with a proper killer front stage and you feel bad because your imaging is crap  |
Gold Member Username: Carguy
Post Number: 1744 Registered: Nov-04
| Posted on Monday, March 07, 2005 - 04:08 pm: |
Definitely get rear speakers if you're not planning to have any sub. Spend a little cash on a good pair. Tune the HU/amp to send mid bass to the rears. This way you will get "fuller" bass inside the cabin.
Post Number: 36 Registered: Dec-04
| Posted on Monday, March 07, 2005 - 11:39 pm: |
Yeah Jonathan I'm sure you're imaging is a lot better than mine. But for most people, they really can't tell the difference. Once you start to get higher end, the hundreds of dollars that you are spending are getting you less and less noticeable difference. To most people, its not worth it. Especially since most people don't have any idea on how to set up a nice front sound stage. Rear speakers give you a nice sound without as much effort and cost. But yeah I agree, if you're that much into your music, and you absolutely NEED the best, go with no rears. But seeing how he isn't even getting a sub, I'm pretty sure that doesn't apply to this question |
GA
Post Number: 3449 Registered: May-04
| Posted on Monday, March 07, 2005 - 11:48 pm: |
I was just picking anyway, everyone has their tastes . That's what makes the hobby fun . |
| Posted on Tuesday, March 08, 2005 - 10:43 pm: |
thanks for your input! got one more question, should i keep my rear stock speakers or upgrade them? if i upgrade, any suggestions on which ones to get? |
Post Number: 1823 Registered: Nov-04
| Posted on Wednesday, March 09, 2005 - 12:10 am: |
That'll depend on you. I'd leave your rears alone and work on the fronts. They are more important. |
