Home > Message Board > Car Audio > Speakers > Archive through March 15, 2005 > Need help installing my speakers...
Author Thread: Need help installing my speakers...
howie feltersnatch
I purchased some infinity kappas, but i need to put the tweeters in. I have a 98 rodeo, so i need to remove the door panels to get them in. if anyone has instruction on how to do this, it would be greatly appreciated. i believe the honda passport is basically the same, if not exactly. thanks for your help guys!
Username: Geekbike
Post Number: 46
I've never dealt with that door, but most are generally the same. Check the bottom of the door for screws and any little pockets for hidden screws. Most times, there also is a screw hidden behind the handle assembly. Use a screw driver or flat wrench to pop out the little stickin things that outline the door. Once you have the door unattached, you might have to disconnect the handle where it connects to the release mechanism.
It shouldn't be to hard, just look around and think about it.
Home > Message Board > Car Audio > Speakers > Archive through March 15, 2005 > Need help installing my speakers... [ « Previous ] [ Next » ]
