Thread: Sub ohm's? |
New member Username: Dsgbthuglife
Post Number: 3 Registered: Feb-05
| Posted on Friday, February 25, 2005 - 10:56 pm: |
how many 4ohm subs would it take for them to handle a 1ohm load?thanks.. |
Bronze Member Username: Gavbo211
US
Post Number: 20 Registered: Jan-05
| Posted on Saturday, February 26, 2005 - 12:36 am: |
3 subs. each time u divide by two so 2 4ohm subs would run at 2 ohms, and 3 4ohm subs would run at 1 ohm. |
Post Number: 5 Registered: Feb-05
| Posted on Saturday, February 26, 2005 - 03:37 am: |
is there a diffrence in 1.33ohm and 1ohm?or is that still a 1ohm load?thanks.. |
Silver Member Username: Bdonkersgoed
Ontario
Post Number: 125 Registered: Jul-04
| Posted on Saturday, February 26, 2005 - 03:39 am: |
Keep in mind whether your subs are single or dual voice coil . . . this makes a big difference! Regards, Bryan |
Post Number: 9 Registered: Feb-05
| Posted on Saturday, February 26, 2005 - 02:34 pm: |
they are single voice coil subs.. |
Post Number: 10 Registered: Feb-05
| Posted on Saturday, February 26, 2005 - 02:36 pm: |
i seen that 3 subs make 1.33ohm and 4 make 1ohm but if i use 3 for the 1.33ohms would i loose power from the 1 ohm load from the amp? |
Silver Member Username: Taylor17
Kopperl,
Texas
Post Number: 678 Registered: Jan-05
| Posted on Saturday, February 26, 2005 - 03:04 pm: |
It will heart just a little, but not enough to really notice. |
