Thread: AHHHHHHH. Dear god i need advice regarding my new amplifier |
New member Username: Clarion1000
Post Number: 3 Registered: Feb-05
| Posted on Thursday, February 24, 2005 - 08:19 am: |
Am i able to bridge my two 700 watt max kenwood subs to my 1000watt clarion DPX1001.1 amp. THANX A BUNCH |
Silver Member Username: Rob315
Cuse,
NY
U.S.
Post Number: 178 Registered: Jan-05
| Posted on Thursday, February 24, 2005 - 08:54 am: |
DOUCHEBAG!! |
Gold Member Username: Carguy
Post Number: 1591 Registered: Nov-04
| Posted on Thursday, February 24, 2005 - 09:57 am: |
Liam when you say bridge, I hope you're referring to wiring. You can combine the 2 subs by wiring them in parallel or in series, depending on your amp. If the subs are DVC and your amp supports 1ohm load, then use the parallel mode. If however, your amp only supports 2ohms, then you better wish the subs are SVC. Read up on SVC and DVC on the internet.
