Thread: 8 Ohms |
honda400ex Unregistered guest |
| Posted on Thursday, February 24, 2005 - 03:50 am: |
I have 2 12 in subs. They are 4 ohm dvc. Is there anyway to wire them to 8 ohms, so I could hook them up to my reciever in my house? Or is it a bad idea to hook them up inside? |
Bronze Member Username: Krijgy
Smithfield,
Virginia
United states
Post Number: 65 Registered: Jan-05
| Posted on Friday, February 25, 2005 - 10:16 am: |
connect them in series that will make the ohms additive and increase the resistance to 8 ohms |
RodOnIsle Unregistered guest |
| Posted on Tuesday, March 08, 2005 - 09:19 pm: |
I have the same question but the other way around. I have speakers with 2 pairs of inputs - 1 hi and 1 low. Each are listed as 6 ohm. My amp is listed as 4 to 16 ohm. How and WHY should I wire up these speakers? Series, paraelle, or use some kind of resistor where? Thanks for any ideas. |
