Home > Message Board > Car Audio > Speakers > Archive through March 15, 2005 > INFINITY KAPPA 6x9 or 6.5
Author Thread: INFINITY KAPPA 6x9 or 6.5
Username: Alexochoa
Tucson, Arizona
Post Number: 11
I have a 98 altima, and for my rears, i was thinking of just cutting out for 6x9 kappas. Would there be a big diffrence. i'm going to amp my kappa's with extra 75 watts from an amp.
My quesiton is; should i go ahead with cutting or just keep the 6 1/2's
Username: Sanchez5888
Post Number: 34
Just keep the 6.5s. I have the 6x9s and they're amazing, especially with an amp, you can hear them from a good quarter mile away.
Username: Suleman36
Post Number: 183
whats better ? the kappas or the perfects for the 6.5's
Post Number: 37
The kappa perfects are better. Get the infinity kappa 6.1 component set. Buy them off ebay, there are a lot of reputable sellers on there that will save you a hundred dollars or more. If the guy has no feedback, no matter how cheap the speakers are, dont take the chance. Just go for one thats selling for like 200 and has a lot of good feedback and you just saved yourself a little bit over 100 bucks.
Home > Message Board > Car Audio > Speakers > Archive through March 15, 2005 > INFINITY KAPPA 6x9 or 6.5 [ « Previous ] [ Next » ]
