Home > Message Board > Car Audio > Amplifiers > Archive through February 27, 2005 > Someone please help!!!! Amp troubles!
Author Thread: Someone please help!!!! Amp troubles!
Username: Ryanman09
Regina, Saskatchewan
OK! So i have a 12" Audiobahn flame excurtion AW121T. My amplifier is a phoenix gold xs2500, its only 1000W, the sub is 1100W, I feel its not getting enough power. I also have an Ultralinear UL2200D amp which is 400W. Is there a way I can connect both to the sub without seriously injuring it?
Username: Carguy
Post Number: 1587
Ryan, you are not under powering the subs. You talk like 1000w is nothing. Let met tell you, 300w rms of real power is enough to shake the trunk/mirrors and windows in your car.
Chances are, if 1000w is not enough power, then your amp is not putting out real numbers.
Try listening to a great 400w amp. It will sound louder than 1000w cheap ones.
For your 2nd question, you can not combine 1000w amp with 400w amp.
Home > Message Board > Car Audio > Amplifiers > Archive through February 27, 2005 > Someone please help!!!! Amp troubles! [ « Previous ] [ Next » ]
