Thread: Need 200A alter, but ones I find say 100A!!!!HELP glasswolf |
| Posted on Monday, February 16, 2004 - 03:23 pm: |
hi, i need about a 200A alternator to power my amps but all the so called 200A's a find say they will put out 100A at idle.....like this one http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=38638&item=245 9497610 its like $220 shipped but will it do for a 1200 watt RMS system like mine??? is this the same marketing ploy used by audio co. when they say something like "1400 watt max" but only put out like 500 watts RMS??? If the alt. i listed above it a joke, then where can i get an alt. to supply my amps w/ the current they need????(2 JBL BP600.1's) help me out here.....please |
Post Number: 1223 Registered: 12-2003
| Posted on Monday, February 16, 2004 - 04:56 pm: |
almost all alternators put out less current at idle. when the engine RPM goes above about 2000RPM, the alternator will put out it's rated power, and usually go from 12V up to 14.4V That's normal, and to be expected. Don't worry about it. As long as the car is actually moving, you're in good shape. You probably won't have the system at full volume at a stop light anyway if you have any thought for other people, so that won't be a concern. At competitions, you can either run the motor above idle, or rely on the batteries and have the engine off. It depends on who sponsors the event.
| Posted on Tuesday, February 17, 2004 - 09:46 pm: |
yea...but will the alternator on the link have the juice i need for my amps??? |
Post Number: 1241 Registered: 12-2003
| Posted on Wednesday, February 18, 2004 - 12:30 am: |
if it puts out 200A at full, you should be good.
