Home > Message Board > Car Audio > Amplifiers > Archive through February 27, 2005 > What do these words mean
Author Thread: What do these words mean
ok on my amp there are three little things to hook wires into....one for ground, then power, then one that says REM??? what does that maen? i got a little spool of wire in my amp kit that says remote turn-on wire...is that what goes there and waht does it hook to? on the diargram in the box that game with my amp there is a picture of a wire going from taht REM slot to the radio, but all that i no of taht goes there are my rca cables.....right?
any help at all will be appreciated
Username: Joebruce
KY
U.S.A.
Post Number: 104
Yes the remote wire hooks on the amp where it says REM and then it runs back to your head unit and there should be a blue wire on the back of your head unit,it should say remote.That wire is wut actually turns on your amp,when you start your car the hu comes on then sends a signal through that little wire to your amp to turn your amp on.
ahhhh i see i see thank you very much u saved me, i almost concidered not hooking anything in there at all, but hey waht does REM stand for?
Username: Joebruce
KY
U.S.A.
Post Number: 105
remote,since its kinda like a remote it "turns on" your amp.
gotcha, thanks
Home > Message Board > Car Audio > Amplifiers > Archive through February 27, 2005 > What do these words mean [ « Previous ] [ Next » ]
