Thread: Setting up my new CDA-9833, I-personalize settings |
Matty3d Unregistered guest |
| Posted on Tuesday, February 22, 2005 - 03:08 am: |
Hey Everyone, I just picked up and had my new head unit installed today. The head unit is pretty great, and I plan on getting the KCA-420i pretty soon but wanted to get the deck in first since I have an Itrip too. Has anyone played around with the I-personalize settings much? I had the installer setup the digital time correction, but has anyone had much luck at programming the EQ User presets, and crossover settings? I'm went on Alpine's site to play around with it, but I honestly have absolutely no idea as to how the crossovers should be set, nor really what would be good for the other 6 EQ settings. Has anyone successfully gotten their settings setup? Would anyone be willing to help me out by offering suggestions (or maybe even the files they used)? Thanks, MAtt Currently my setup is as follows: -front speakers (Infinity 62.5I 2way 6.5" speakers) powered by deck -400W Phoenix gold amp powering the following: -rear speakers 4x6" speakers (at this hour I can't remember the brand) -10" Ultimate Pro Sub (also powered by the amp)
Bronze Member Username: Kklagge
Post Number: 81 Registered: Dec-04
| Posted on Tuesday, February 22, 2005 - 10:50 am: |
I just adjusted mine in the HU....same settings and a lot easier in my opinion....the online one is so you can burn it to a disc and put it in the HU...don't see the need unless you lose power to the HU a lot. |
