Home > Message Board > Car Audio > Amplifiers > Archive through February 27, 2005 > Symbilink question...
Author Thread: Symbilink question...
Username: Scab12886
Post Number: 93
i was looking to get zapco reference amps for my components and sub. i had seen the symbilink stuff and don't really know what it is. can anyone explain it a little to me please? what are the benefits for having it?? also, how much does it cost to get the symbilink balanced lines stuff? thanks in advance.
Username: Jonathan_f
GA
Post Number: 3328
Symbilink is a balanced 16V DIN cable used to supply the amplifier, as opposed to typical differential RCAs that people used. The benefit is a drastically reduced noise floor, rejection to inducted noise from components in the car. It lessens the chance of alternator whine in a car. It's pretty much the cleanest signal you're going to get in a car.
Username: Scab12886
Post Number: 94
thanks a lot jon. how much would it cost? do you know?
GA
Post Number: 3330
There are so many different Symbilink processors so that you can accomodate a variety of systems. Best way to get it IMO is by using their SP4-SL Preamp, it serves as an equalizer, a system volume control, controls sub level and has a crossover for the sub, and a fader, plus it converts the incoming unbalanced signal to a Symbilink balanced output. Then you could buy the cables and run them to the amps. Not exactly sure on specific price for the cables, the SP4-SL processor is $400 or less (less online).
Home > Message Board > Car Audio > Amplifiers > Archive through February 27, 2005 > Symbilink question... [ « Previous ] [ Next » ]
