Thread: Help with dual vocie speakers |
New member Username: Bootykang
Post Number: 6 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 10:03 pm: |
i have two extreme 12 inch 500 watt dual voice speakers. I have a 500 wat mono amp and have all that stuff hooked up. But i dont know how to wire the speakers. Someone help thanks |
| Posted on Monday, February 21, 2005 - 10:32 pm: |
well the way it sounds you will need another amp period. i really wouldnt brigde them this could break the amp. |
Post Number: 7 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 10:39 pm: |
foreal dam, well i have and 200 watt 2 channel amp i got from walmart would this help |
Bronze Member Username: Sublime420
Ca
Us
Post Number: 71 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 10:57 pm: |
how many ohms is each voice coil? is the amp 2 ohm stable? is it 1 ohm stable? |
Post Number: 8 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 11:03 pm: |
each speaker is 4 ohms |
Silver Member Username: James1115
Wilton,
Ct
Post Number: 993 Registered: Dec-04
| Posted on Monday, February 21, 2005 - 11:07 pm: |
what amp do you have? |
Ca
Us
Post Number: 73 Registered: Jan-05
k. so you have two 4 ohm DVC subs. is the amp stable at 2 ohms?
Wilton,
Ct
Post Number: 995 Registered: Dec-04
| Posted on Monday, February 21, 2005 - 11:13 pm: |
you cant run two dual 4ohm coil subs mono at 2ohms. 1 or 4 |
Post Number: 9 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 11:14 pm: |
i have xtreme amp too and yea it says its 2 ohm stereo stable and 2 ohm mono stable |
Wilton,
Ct
Post Number: 996 Registered: Dec-04
| Posted on Monday, February 21, 2005 - 11:15 pm: |
if its 2ohm stereo stable its not 2 ohm mono stable. 1ohm stereo is 2ohms mono and 2ohms stereo is 4 ohms mono. |
Post Number: 10 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 11:17 pm: |
its says its a mono block amp with a bulit in crossover whaterver that means |
Ca
Us
Post Number: 74 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 11:18 pm: |
k. two more things. are the subs 500 watts max, or 500 watts RMS? and what is the amps make and model exactly? |
Wilton,
Ct
Post Number: 998 Registered: Dec-04
yeah that will help. |
Bronze Member Username: Bootykang
Post Number: 11 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 11:20 pm: |
500 watts max, the name says extreme made by directed audio well it says in the book its 1500X 2-ohm mono stable
Post Number: 12 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 11:21 pm: |
it does'nt even say what the RMS is |
Ca
Us
Post Number: 76 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 11:26 pm: |
k. that amp only does 250 watts RMS @ 2 ohms. those subs can take 250 watts. so get one more amp just like the one you have, then you'll be fine. |
Post Number: 13 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 11:29 pm: |
ok but how would i wire one up to the amp
Ca
Us
Post Number: 77 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 11:39 pm: |
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=1+woofer&WoofImp= Dual+Voice+Coil+-+4+ohms+x+2&image.x=22&image.y=7 use wiring option #1 |
Post Number: 14 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 11:48 pm: |
thanks
xxdick83xx311 Unregistered guest |
| Posted on Wednesday, February 23, 2005 - 04:00 pm: |
Im going to be running a single MTX 8512-44 12" off a Phoenix Gold Xenon x 400.1.....I know I want to be running it parallel...how exactly do I do that?Do i just want to run + to + and - to - on the amp and run short wires around to the other posts the same way? |
