Home > Message Board > Car Audio > Speakers > Archive through March 15, 2005 > Engine whining coming through speaker...
Author Thread: Engine whining coming through speakers....
Zach K
Hi, I recently completed my system... got new speakers, amps, subs, everything. It all sounded good until I started to put thing s back together and such like putting back the head unit and putting the dash back on. Now when I turn on the car, I hear a certain whine and when i rev the when the whine rises and falls in tones with the revs. I can also hear when the head unit starts a cd or somethin through the speakers... this is all frustrating the heck outta me... what do i do!?!?
Username: Xxkmfdmxx
St. Petersburg, FL
Post Number: 344
Usually a poor ground does that. Try grounding your headunit and amp to a different ground.
Username: Dubdw7kota
WILMINGTON, NC
Post Number: 22
also move ur rca cable away from ur power wire... thats what caused mine... and ground as well...
Username: Krijgy
Smithfield, Virginia
United states
Post Number: 66
yeah like matt said, run your remote and rca cables down one side of your car and your power wire down the other.
fafsa
that used to happen to me too, i fixed the ground and everything and it did lessen the problem, but the way i completely got rid of it, i bought an active crossover and it cleaned up the signal coming from the rcas, now it just sound super clean
Home > Message Board > Car Audio > Speakers > Archive through March 15, 2005 > Engine whining coming through speaker... [ « Previous ] [ Next » ]
