Thread: 2 channel amp to one speaker????????? |
| Posted on Monday, February 21, 2005 - 02:09 pm: |
I am new to this, but I just insatlled a 250 watt 2 channel amp with 1 1000 watt 10" speaker, and I was wondering if you could use both channels for the one speaker to get max power? |
Bronze Member Username: Sublime420
Ca
Us
Post Number: 52 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 02:29 pm: |
you might be able to. check and see if the amp is bridgable. if it is, then you problly take the positive form channel 1 and the negative from channel 2 and hook that up to the speaker. ya |
New member Username: Spreadhead0614
Post Number: 1 Registered: Feb-05
| Posted on Monday, February 21, 2005 - 02:41 pm: |
Thanks Sublime420, I was going to try that but I didnt want to mess anything up, so I thought I would ask first. |
Ca
Us
Post Number: 57 Registered: Jan-05
| Posted on Monday, February 21, 2005 - 04:59 pm: |
just make sure your amp is bridgable. not all 2 channel amps are, but most are. |
