Thread: How many watts |
New member Username: Point78
Post Number: 1 Registered: Feb-05
| Posted on Sunday, February 20, 2005 - 03:54 pm: |
i have 2 kicker sl10l5's dual 2ohm voic coils 450 watts rms and 900wats peak what size amp and should i look into and should i use a mono amp or more channels |
Silver Member Username: Taylor17
Kopperl,
Texas
Post Number: 544 Registered: Jan-05
| Posted on Sunday, February 20, 2005 - 05:45 pm: |
Check out Jbl, think it is called the 1000.1 and the Hifonic's BX1000D. They are Mono, they will work fine. |
Silver Member Username: Addicted2bass
Miami,
FLORIDA
Post Number: 211 Registered: Nov-04
| Posted on Sunday, February 20, 2005 - 06:11 pm: |
i dont think the hifonics would work because it rated at 1000watts at 1 ohm and he cant wire 2 dual 2ohm voice coils at 1 ohm unless its on a 2 channel stereo amp. If he bought the hifonics youll have to wire it at 2 ohms which is only 250 watts to each sub and they're overrated so about 175 to each sub which is'nt enough.And i dont think jbl makes a thosand watt amp, i thin its jl audio makes the 1000watt amp, which is to much power becawuse they're underrated so he'll be getting around 150watt's extra to each sub which will blow it. You could get the amp though as long as you listen for distortion threw your subs. if ou hear any turn it down a little http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=48598%26item%3D5752657694 %26 maybe this amp shoud work |
