Thread: Possible for bass to damage HU? |
Silver Member Username: Xxkmfdmxx
St. Petersburg,
FL
Post Number: 339 Registered: Oct-04
| Posted on Sunday, February 20, 2005 - 01:25 pm: |
I was playing a couple bass tracks pretty loud then all of a sudden my headunit start resetting, It stays on but the screen keeps resetting. It says hello each time you turn it on, It gets to HE then resets and keeps doing it. I cant do nothing. The power stays on since the screen is light at all times it just keeps resetting allowing me to do nothing to it. Checked all wireing and its fine. Heres a video of it doing it incase you dont understand what im saying lol http://www.geocities.com/whitetribal/MVI_0109.AVI small 1mb download |
St. Petersburg,
FL
Post Number: 340 Registered: Oct-04
| Posted on Sunday, February 20, 2005 - 06:42 pm: |
bump, Would like to know if this is fixable or not. |
St. Petersburg,
FL
Post Number: 343 Registered: Oct-04
| Posted on Monday, February 21, 2005 - 09:09 pm: |
I found out my power wireing comeing from my fuse box to headunit is getting quite hot, Could this be the reason its resetting like this? |
New member Username: Trikosuave
Post Number: 5 Registered: Feb-05
| Posted on Tuesday, February 22, 2005 - 12:19 pm: |
Is it a detachable face? if the connection is loose it could come offset when the bass hits. Also try running your yellow constant straight to the battery like you would an amp and see if it still does it. Remember that the ground is just as important as the powe rso make sure that is good too. go from black wire straight to chassis in the radio area instead of using the factory harness' ground. bad ground will cause extra heat on the power wire too. |
Post Number: 6 Registered: Feb-05
| Posted on Tuesday, February 22, 2005 - 12:21 pm: |
If you find out it is the Deck, then i have a great deal on my JVC LH300 (http://www.bizrate.com/marketplace/product_info/overview/index__cat_id--11850000 ,prod_id--11621154,mkt_id--18242768,rf--qgt,qcid--590484036324,kw--jvc+lh300.htm l) email me at trikosuave@hotmail.com and i give you specs and price. |
St. Petersburg,
FL
Post Number: 347 Registered: Oct-04
| Posted on Tuesday, February 22, 2005 - 01:25 pm: |
Everything I saw was wired corrrectly, and it worked fine before playing music this loud. The face plate doesnt come off though. I'll try what you said and get back to ya. |
St. Petersburg,
FL
Post Number: 363 Registered: Oct-04
| Posted on Wednesday, February 23, 2005 - 08:55 pm: |
Found out what the problem was. The ground on my battery was loose. So the battery hasnt been rechargeing. Currently chargeing up the battery, And seems to be helping alot. |
St. Petersburg,
FL
Post Number: 364 Registered: Oct-04
