Home > Message Board > Car Audio > Amplifiers > Archive through March 04, 2005 > 2 amps one cap
Author Thread: 2 amps one cap
is it possible to connect the Power distribution block after the capacitor so that I can connect two amps?
Username: Firni7845
Post Number: 16
if you have a power distribution block with 2 outputs you can connect the cap after the dist. block, you dont have to put the cap before it. take the first output and hook the cap to it and from the cap to the amp. and use the second one to hook up your second amp. hope that helped.
Username: Pr24mbklyn
does any one jnow how to connect two amps together
need help trying to connect two amps together
Username: Kojak28
Augusta, GA
Post Number: 23
Hey man, you don't even have to use a dist block. I am running a cap for 2 amps. I think that's wut FC was trying to say.lol.
Username: Kojak28
Augusta, GA
Post Number: 24
1 cap 2 amps
Username: Glasswolf
NorthWest, Michigan
Post Number: 7451
you should really just use one cap per amp as close to each amp as possible to be effective.
you also should have 1Fd of capacitance per 1000 watts of power, and that won't replace the need for a beefed up charging system if you have dimming lights.
Username: Kojak28
Augusta, GA
Post Number: 28
Glass you are absolutely correct. But couldn't he wire 2 amps off a 2 farad cap if need be?...instead of a dist block,more wires,etc.
Home > Message Board > Car Audio > Amplifiers > Archive through March 04, 2005 > 2 amps one cap [ « Previous ] [ Next » ]
