Thread: Wolf I need your Help on my amplifier |
Bronze Member Username: Alpineblaster
Post Number: 54 Registered: Jan-05
| Posted on Saturday, February 19, 2005 - 01:41 pm: |
i hooked up two alpine type xs and an orion 2500D and it just doesnt sound right it doesnt sound like 2500watts plus it keeps blowing fuses abd is leting off a bad smell I just think its not performing as it should you have any idea what it might be? |
New member Username: Sound_maniac
Post Number: 4 Registered: Feb-05
| Posted on Saturday, February 19, 2005 - 01:47 pm: |
What's your cable gage? Seems to be a current problem. |
Post Number: 55 Registered: Jan-05
| Posted on Saturday, February 19, 2005 - 06:22 pm: |
im running 4 guage with 80 amp fuses is that to small |
Silver Member Username: Hdubb
Farmington,
Nm
Usa
Post Number: 740 Registered: Nov-04
| Posted on Saturday, February 19, 2005 - 06:59 pm: |
yes. go to 0 gauge with 100 to 150 amp fuse, if you can find one. check your ground too. hopefully the smell isnt the subs voicecoils burning |
Silver Member Username: James1115
Wilton,
Ct
Post Number: 894 Registered: Dec-04
| Posted on Saturday, February 19, 2005 - 07:00 pm: |
yes that amp can pull upwards of 200 amps. You need 0 guage power+ gound, a high powered alternator, prob a new deep cycle battery, you just cant throw a amp like that in your car and hope it all waorks out. That is some serious power dude! |
Post Number: 6 Registered: Feb-05
| Posted on Saturday, February 19, 2005 - 07:29 pm: |
Think you have your answer sir! |
Post Number: 56 Registered: Jan-05
| Posted on Saturday, February 19, 2005 - 07:53 pm: |
ya thanks im gonna go chang that stuff now and get back to you guys |
