Home > Message Board > Car Audio > Amplifiers > Archive through February 21, 2005 > Need Amp Help!?!
Author Thread: Need Amp Help!?!
Username: Jmills11
I have a 1100w amp that i had installed and the guy installing it said the amp was fried because on of the fuses on the amp keeps blowing. the amp has never been used and i dont see how a fuse can blow without the amp being on. the fuses are 25 should i go higher? Help
Username: Sound_maniac
Don't use fuse higher than original ones. If it keeps blowing, your outputs are burned. You'll need a repair shop. Hope for you you have a warranty... Good luck.
Other thing. Look to have enough current to your amp, it can be a cause to burned outputs. If it's it, you'll always burn outputs and be to repair shop.
Home > Message Board > Car Audio > Amplifiers > Archive through February 21, 2005 > Need Amp Help!?! [ « Previous ] [ Next » ]
