Home > Message Board > Car Audio > Amplifiers > Archive through February 21, 2005 > Tuning my amp
Author Thread: Tuning my amp
Username: Jeze
Post Number: 18
So I just purchased a Boss 1500D amplifer. Their manual sucks bad.
My question is, what do all of these switches mean and what do they do exactly? I have a very vague idea.
- Phase shift switch
- Variable Low-pass filter
- Variable Sub-sonic filter
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 306
Phase shift is used to strap two amps togather. If only one amp then set it to zero. Variable low pass filter is the crossover frequency for the subwoofer. It cuts out frequencys over the set frequency that you dont want the subwoofer to produce. The Variable sub-sonic filter is for use with a ported box. It will cut out frequencys below the set frequency. If you dont have a ported box then turn the sub-sonic filter to the lowest frequency. If you do have a ported box then set it about 10hz lower that the boxes tuned frequency.
Username: Jeze
Post Number: 19
Great..Thanks
Username: Jeze
Post Number: 20
Can the box frequency can be recognized by the FS (HZ) or the Fb (HZ)? I know the FS is the same as my sub so I'm assuming its the Fb (HZ).
I'm actually looking at my box manual right now trying to understand it.
Home > Message Board > Car Audio > Amplifiers > Archive through February 21, 2005 > Tuning my amp [ « Previous ] [ Next » ]
