Home > Message Board > Car Audio > Amplifiers > Archive through February 21, 2005 > Glasswolf, what amp for Dynaudio spea...
Author Thread: Glasswolf, what amp for Dynaudio speakers?
Doug W.
I know glasswolf has a set of dynaudio speakers, so can you or anyone else maybe recommend a good 2 channel amp for a Dynaudio system 240 GT component set? The website says they have 100 watts continues power handling but I talked to a guy at a shop and he said they can handle more, his exact words were "They are power hungry maniacs". So can anybody tell me a good amp to run them?
Username: James1115
Wilton, Ct
Post Number: 881
Orion 2100 HCCA @4 ohms stereo if you got the loot for it!
Doug W
Which of these amps would work best with the Dynaudio system 240 GT component set? They RMS 100 watts. Would 150 watts be to much more for these speakers? I mean I would like to try to keep them working for a while. How are soundstream amps? I would like to go with one of those because they are the cheapest but if there are better amps out there I would rather get it?
Or is there another amp in the $100-$200 range that I don't have here that would be better?
JBL PX600.2 (RMS 180x2 @ 4 ohms) ($340)
Zapco 350.2 (RMS 100x2 @ 4 ohms) ($315)
Hifonics Zeus ZX6000 (RMS 150x2 @ 4ohms) ($230)
Soundstream VGA400.2 (RMS 100x2 @ 4 Ohms) ($200)
VGA600.2 (RMS 150x2 @ 4 Ohms) ($230)
Home > Message Board > Car Audio > Amplifiers > Archive through February 21, 2005 > Glasswolf, what amp for Dynaudio spea... [ « Previous ] [ Next » ]
