Thread: Mono amp-2 subs |
New member Username: Kevlap
Post Number: 1 Registered: Feb-05
| Posted on Friday, February 18, 2005 - 12:00 pm: |
Could someone please tell me how to run the speaker wires from a mono amp to 2 subs. It is a class d amp, bridgeable. Thanks. |
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 297 Registered: May-04
| Posted on Friday, February 18, 2005 - 04:26 pm: |
we have to know what ohm load your amp and sub can handle first. |
Bronze Member Username: Marley289
Post Number: 100 Registered: Nov-04
| Posted on Friday, February 18, 2005 - 04:59 pm: |
well check out this site it has numerous different ways you can wire you subs (look on the right side of the page for the subwoofer wiring guide, then you can figure it out from there) http://www.cardomain.com/shop/subwoofers
Louisville,
KY
Post Number: 2 Registered: Feb-05
| Posted on Saturday, February 19, 2005 - 01:05 pm: |
Thanks, it has been a while since I have installed any car audio components. Subs are 4 ohm, with a 2 ohm stable amp. Coustic 500W amp with 2 Memphis 10" subs-sounds awesome. I had the MTX road thunder subs before, and I have to say the Memphis handles bass and thumps a little harder!! |
