Home > Message Board > Car Audio > Amplifiers > Archive through February 21, 2005 > Fuse keeps blowing on amp
Author Thread: Fuse keeps blowing on amp
i have a rockford fosgate amp and everytime i try and hook it up to my two rockford punch p1s the fuse on the amp blows, i've blown 5 different fuses and i can't figure out the problem. can someone plz help
maybe the way the subs are wired, the ohm rating is too low for your amp to handle.
Username: Marley289
Post Number: 101
first off, are you sure that it is the right size fuse? second it could be like what anon said, the ohms are too low and your amp isnt stable at that amount of ohms.
(woohoo silver member)
Home > Message Board > Car Audio > Amplifiers > Archive through February 21, 2005 > Fuse keeps blowing on amp [ « Previous ] [ Next » ]
