Thread: What do you think of this sub and amp combo? |
| Posted on Wednesday, February 16, 2005 - 08:21 pm: |
i need bass hopefully this will do it what do you think? http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13596 ^ AW1008T sub(1000 W RMS!!) paired with http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14030 or http://www.cardomain.com/item/KENKAC9102D im also considering an audiobahn eternal(not immortal) what do you guys think?
Silver Member Username: Taylor17
Kopperl,
Texas
Post Number: 502 Registered: Jan-05
| Posted on Wednesday, February 16, 2005 - 08:34 pm: |
With either of the amp's, you will only git 500 watt's out of each. I would recomend going with the eternal, and a different amp. |
| Posted on Wednesday, February 16, 2005 - 08:38 pm: |
what do you mean they will only give me 500w it says 850rms for the kenwood. isnt kenwood reliable? |
Kopperl,
Texas
Post Number: 503 Registered: Jan-05
| Posted on Wednesday, February 16, 2005 - 09:04 pm: |
That amp put's out 850 watt's at 2 ohm's, the sub's can only be wired to a 1 ohm, or a 4 ohm load. And sense I don't think that amp is stable at 1 ohm, the only way to use that amp is to wire your sub to 4 ohm's, and the amp put's out 500 watt's to 1 sub at 4 ohm's. To git the 850 watt's, the sub need's to be 4 ohm dvc. |
