Home > Message Board > Car Audio > Security Systems > Archive through June 01, 2006 > Wanting to install 550esp viper with ...
Author Thread: Wanting to install 550esp viper with voice box
Username: Casper22hptva
Virginia
Post Number: 21
is this a good idea to try my self? or should i take it some where how much would it cost me?????????
Username: Whiteaurora01
Post Number: 8
voice box sucks it was so 90's. and also it causes more problems. think about it, it draws attetion. people will f#c* with your car just to hear it talk.
Username: Ps1k0
Post Number: 208
it all depends on how confident and comfortable you are with putting it in yourself. just make sure you read the install manual thougroughly and double check all wires before making connections and you should be ok. the 550 can take a little while to install for a beginner, so free up a day, start early, and don't rush and you'll be done in no time.
Home > Message Board > Car Audio > Security Systems > Archive through June 01, 2006 > Wanting to install 550esp viper with ... [ « Previous ] [ Next » ]
