Thread: I need a 1000w amp<<< |
| Posted on Tuesday, February 15, 2005 - 08:48 pm: |
i need a 1000w amp for my 2 12's, anyone wanna sell or got suggestions? |
Silver Member Username: James1115
Wilton,
Ct
Post Number: 727 Registered: Dec-04
| Posted on Tuesday, February 15, 2005 - 09:28 pm: |
what kind of 12's? |
| Posted on Wednesday, February 16, 2005 - 02:06 pm: |
dual, nothin special im not lookin to blow anyone away, just sound good |
Wilton,
Ct
Post Number: 766 Registered: Dec-04
| Posted on Wednesday, February 16, 2005 - 02:38 pm: |
I would not put a 1000 watts to those subs if I were you. I would try something like 250/sub |
Bronze Member Username: Perrydog
Flint,
Michigan
Post Number: 66 Registered: Jan-05
| Posted on Wednesday, February 16, 2005 - 10:05 pm: |
ya i was gonna buy sum duals then i checked in to the specs on them and asked around so far i havnt found out that dual have a good rep, iv heard ya they sound good for about 3 mnths then blow or fry or just stop pounding,deff dont throw 500 to each sub |
Unregistered guest |
| Posted on Saturday, February 19, 2005 - 02:36 pm: |
I agree, i don't think you need to put 1000 watts to your subs, but if you are looking a clear powerful sound, you might want to consider the JL 500/1. I had this amp when i had two 12s and it was more than enough power then i needed. The rms is 500, but that is under rated, its more like 700-800. |
