Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > Orion or USAcoutics??
Author Thread: Orion or USAcoutics??
Username: Gavbo211
US
Post Number: 15
Hey i was lookin at an Orion 6002 amp, 150x2 @4ohms, or the USAcoutics USC2200, 200x2 @4ohms but its rated at 12.9 volts instead of 14.4 so i know it makes more power than that. They are both around the $220 region and i was wonderin which is better? ill be running 3 JL Audio subs of this amp, 2 10WO's and a 10 W3V2 (yes i know its weird but thats what ive got). But neway any amp advice would be great thanks.
Username: A3forme
Post Number: 336
Okay....neither are going to be a good choice. Your two 10w0 need 125w RMS and the 10w3v2 needs 250W to run decently. So you a tad short on power.......
If you're going to run 3 subs...they really need to be all the same
Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > Orion or USAcoutics?? [ « Previous ] [ Next » ]
