Thread: 4 channel amp suggestions |
| Posted on Monday, February 14, 2005 - 01:52 pm: |
All, I bought Rockford Componet door speakers 6.5 for a miata, And looking for good amp suggestions. 1. looking at 4 channel amp, 2 channels for door speakers, bridging the other 2 channel for sub I appeciate any suggestions, its just that there is so many options, and I am looking for the most clear/bang for my money. Also what is it about ohms? thanks, newbie |
counterbond Unregistered guest |
| Posted on Monday, February 14, 2005 - 02:35 pm: |
you could start out with a 4-channel amp...maybe..im thinkin the new infinity or a rockford, or if you push a shopping cart, you could maybe sell some cans and afford the DUAL 480watt amp from best buy. |
Silver Member Username: James1115
Wilton,
Ct
Post Number: 700 Registered: Dec-04
| Posted on Monday, February 14, 2005 - 04:42 pm: |
try a PPI pcx 480 or 4125 that will compliment your steeo very nicely. |
| Posted on Tuesday, February 15, 2005 - 08:29 am: |
All, I plan to put the amp under the seat in my miata, any suggestions. newbie |
