Thread: Blowing an Amp? |
| Posted on Sunday, February 13, 2005 - 09:45 pm: |
Hey guys, I have some POS Wal Mart brand (VR3) 5 channel amp.....I was only running 1 channel of it(the subwoofer one) but had 3 subs hooked up in parallel. This was producing a 1.3 ohms load to the amp. Would this have blown it out, because the protection light is on and I can not get it to shut off. Thanks |
Silver Member Username: Xxkmfdmxx
St. Petersburg,
FL
Post Number: 321 Registered: Oct-04
| Posted on Sunday, February 13, 2005 - 10:11 pm: |
Most likely that did blow it, I cant imagine the VR amps walmart sells being stable under 2 ohms. |
Unregistered guest |
| Posted on Friday, February 18, 2005 - 02:57 am: |
hey, all you have to do is take off the 12 volt line to the amp and then put it back on! it will reset the amp |
