Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > Amp Cuts out at higher volumes
Author Thread: Amp Cuts out at higher volumes
Username: Xxkmfdmxx
St. Petersburg, FL
Post Number: 318
A friend of mine is having problems with a MTX amp in his car. Max volume on the HU is 40, When he puts it at like 27 the amp stops giving output, But still remains on, If you put the volume down a couple the sub will come back on. I tried two different grounds and still the same problem. What could be wrong?
Username: Carguy
Post Number: 1520
Check your gain/level control. It might be set too high. Also check bass boost control too.
Username: Xxkmfdmxx
St. Petersburg, FL
Post Number: 319
Alright, I had a feeling it had something to do with the gain. I think he had it set at max but not sure. Was set high though.
Username: Xxkmfdmxx
St. Petersburg, FL
Post Number: 322
Lowered the Gain, Still cuts out. Anything else it could be?
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 288
which amp is it?
Username: Xxkmfdmxx
St. Petersburg, FL
Post Number: 323
MTX 311D
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 289
What speaker? How many ohms is the speaker? Is it DVC? I think you are overloading the amp. The amp is 2 ohm stable.
Username: Xxkmfdmxx
St. Petersburg, FL
Post Number: 324
Its a DVC 4 ohm sub. I ran the amp in my car for awhile and it worked in mine. But not his.
Username: Carguy
Post Number: 1537
What is the preout voltage on his HU? The average is 4v. Maybe his is higher? Start with the gain at minimum and go slowly up. See at what volume level it shuts down with minimum setting.
Are you using rca or speaker level input?
Username: Xxkmfdmxx
St. Petersburg, FL
Post Number: 325
Hes useing RCA. Not sure of the voltage on the HU though. Its a KOSS headunit so its mostlikely average. I'll try that with the gain though.
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 292
The amp can handle 8v pre-outs. It sounds like the amp has problems.
Username: Xxkmfdmxx
St. Petersburg, FL
Post Number: 326
But the amp works fine in my car, And I tried two different amps in his car and same problem.
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 294
maybe it is the head unit.
Username: Vaio
Post Number: 31
yea it can be the HEad Unit are check your wires to make sure they are good make you ground.
Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > Amp Cuts out at higher volumes [ « Previous ] [ Next » ]
