Thread: Ground wire, where to connect? |
| Posted on Sunday, February 13, 2005 - 06:36 pm: |
On the ground wire on your amp, where do you connect it to? Do you connect it to the frame of your truck? |
Bronze Member Username: Joebruce
KY
U.S.A.
Post Number: 69 Registered: May-04
| Posted on Sunday, February 13, 2005 - 06:41 pm: |
Yes,make sure to scrape or sand down the paint first so its pure metal and a clean surface this will give you a better ground connection.Then you can just drill a hole and put a bolt in it with the ground wire in between the bolt and frame.Make sure it is a good three feet away from the amp. |
| Posted on Sunday, February 13, 2005 - 09:36 pm: |
So I can connect it inside the cab of my truck. |
Bronze Member Username: Marley289
Post Number: 88 Registered: Nov-04
| Posted on Sunday, February 13, 2005 - 10:49 pm: |
yea that would be fine, just be careful that you dont drill into anything like wires, lines, etc |
Gold Member Username: Jonathan_f
GA
Post Number: 3229 Registered: May-04
| Posted on Sunday, February 13, 2005 - 10:59 pm: |
Actually, the ground wire needs to be as short as possible, as close as you can possibly get it while leaving a little slack. |
| Posted on Monday, February 14, 2005 - 02:09 am: |
Do you think I can run the ground wire out my door so I can hook it up to the frame? |
New member Username: D1duck
Post Number: 2 Registered: Feb-05
| Posted on Friday, February 18, 2005 - 11:07 am: |
any metal part of the body should do fine for a ground connection. i'd not run a cable out the door. |
