Thread: Alpine 9827 vs. alpine 9830, and hows my system? |
Bronze Member Username: Tips
Post Number: 77 Registered: Jan-05
| Posted on Sunday, February 13, 2005 - 05:07 pm: |
im looking to upgrade the stock system in my car, starting with the HU. i've never had a system before, and im not into competitions or things like that. just something that will last and sounds good, and where i can feel the bass. heres what i have planned so far alpine 9830($250) 2 pioneer 3way front($56) 2 infinity 2way 6802 rear($65) 1 12" alpine type r ($120) a sub amp (dunno what kind) (lookin around 100-150 ebay) total around $620 is it a decent system for the price? also, wil it make a difference if i get the alpine 9827 instead? the only major sq diff i see is the bass engine plus on the 9830 vs. the regular bass engine on the 9827. i have 250 dollars max to spend on an HU. i want alpine, but if u have a better idea for an HU, im open to any suggestions.
Post Number: 78 Registered: Jan-05
| Posted on Sunday, February 13, 2005 - 05:51 pm: |
by the way... its a $50 difference between the 30 and the 27. |
Silver Member Username: Rzarector
Coquitlam,
Bc
Post Number: 214 Registered: Dec-04
| Posted on Sunday, February 13, 2005 - 10:58 pm: |
sounds decent .. u could scrap the rear speakers and get a better pair of fronts or more money to teh amp.. u dont really need rears .. im assuming u are getting the older type r not the 05 model if so get an amp that will deliver 300 - 500 rms power .. mrd m350 gives over 350 watts rms and "retails" for 360 u of course could get it for much cheaper ... unless your buying the sub from a store where u get a good warrenty which doesnt look like it for the price the mrd m350 would be perfect much less risk of blowing it .. |
New member Username: Joe_pilk
Reading,
PA
Post Number: 3 Registered: Feb-05
| Posted on Monday, February 28, 2005 - 11:26 am: |
Definitely scrap those fronts, I would keep the rears, but maybe some polk's or another pair of infinity's up front. If you're not running a 4 channel amp, maybe polk will work a bit better, the db series has very little distortion even when they're only run off a head unit's internal amp, and you can find them online fairly cheap. I work at a circuit city in the mobile audio dept. and they go on sale here for about $80 fairly often, but I know they can be found for about 60-70 online, probably even cheaper on Ebay |
