Thread: How do you guys think this will sound? |
Silver Member Username: Loudon
Post Number: 110 Registered: Jun-04
| Posted on Saturday, February 12, 2005 - 06:47 pm: |
Subs - 3 JL W3v2 Amp - JL 500/1 Slot Ported Box It will be in a zx3 ford focus |
Silver Member Username: James1115
Wilton,
Ct
Post Number: 655 Registered: Dec-04
| Posted on Sunday, February 13, 2005 - 04:48 pm: |
good |
| Posted on Sunday, February 13, 2005 - 07:02 pm: |
not enough power |
Silver Member Username: A3forme
Post Number: 328 Registered: Sep-04
| Posted on Sunday, February 13, 2005 - 08:17 pm: |
Definately have to agree w/ Anon. Serious under-powering going on. |
Silver Member Username: Taylor17
Kopperl,
Texas
Post Number: 453 Registered: Jan-05
| Posted on Sunday, February 13, 2005 - 08:24 pm: |
Could use a little more power, but it should sound good. |
Post Number: 111 Registered: Jun-04
| Posted on Sunday, February 13, 2005 - 09:04 pm: |
yea i was thinking that .. what amp would work well with this setup? any ideas? suggestions? |
Post Number: 112 Registered: Jun-04
| Posted on Sunday, February 13, 2005 - 09:09 pm: |
what about the mtx 1501d? |
Kopperl,
Texas
Post Number: 454 Registered: Jan-05
| Posted on Sunday, February 13, 2005 - 09:10 pm: |
Maby the 1000/1 |
Post Number: 113 Registered: Jun-04
| Posted on Sunday, February 13, 2005 - 09:42 pm: |
1000/1 is wayyy to expensive overpriced in my opinion |
Post Number: 114 Registered: Jun-04
| Posted on Sunday, February 13, 2005 - 10:02 pm: |
what if i went with 2 w3v2s? the 500/1 would push those very nicely wouldnt it? |
Wilton,
Ct
Post Number: 658 Registered: Dec-04
| Posted on Sunday, February 13, 2005 - 10:38 pm: |
yeah it will slam 2 of them nicely but it will also power 3 of them as well. The 1000/1 would be over kill too much power. I ran 3 10w6's that are 3oo rms with 600 watts and they slammed very very nicely so I wouldnt say that they would be underpowered. plus that amp itself is underrated as well. |
Post Number: 115 Registered: Jun-04
| Posted on Monday, February 14, 2005 - 01:44 am: |
so james u have ne suggestions as to an amp to power 3 of em ? what do u think will power them optimaly without having to pay 600 dollars for a 1000/1 p.s i live in norwalk ct |
Wilton,
Ct
Post Number: 672 Registered: Dec-04
| Posted on Monday, February 14, 2005 - 09:07 am: |
Nice man right around the corner. Hey Mike are those w3's dual 2,4, or 6 ohm subs? |
Post Number: 116 Registered: Jun-04
| Posted on Monday, February 14, 2005 - 09:37 am: |
I didnt get em yet I am going to buy them I wasnt sure which ones would be better to power? 2 or 4 ohm? |
Wilton,
Ct
Post Number: 673 Registered: Dec-04
| Posted on Monday, February 14, 2005 - 09:49 am: |
Hey Mike I think I got a combo that would work really well for you. Get the dual 6ohms run them at 1ohm mono to a orion Hcca 250G4 or GS or the competition amp but try to locate a G4 or Gs first it will power those subs beautifully. As a matter of fact I would really want to hear that. |
Post Number: 117 Registered: Jun-04
| Posted on Monday, February 14, 2005 - 09:04 pm: |
James thats way to much money for me I can spend 600 on an amp .. although that is a good amp ... i cant do it .. i dont have the funds ... my dad has the 250g4 in his cadillac ... nice amp for sure but couldnt like the kicker kx1200.1, mtx 1501d, those amps push 3 very nicely? |
Silver Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 284 Registered: Oct-04
| Posted on Monday, February 14, 2005 - 09:32 pm: |
The MTX is only two ohm stable. Can you wire 3 speakers down to two ohm? |
Post Number: 119 Registered: Jun-04
| Posted on Tuesday, February 15, 2005 - 12:00 am: |
i think im gonna go with 2 w3s but what ohms should I get the subs in 2,4,6? |
Wilton,
Ct
Post Number: 710 Registered: Dec-04
| Posted on Tuesday, February 15, 2005 - 09:24 am: |
Ok Mike I just got a 250GS which is the same as the G4just all red for $300. Look on Ebay you can find them on there sometimes. I mean you dont have to get that amp but I would. If you want to run three of those I would deff get dual 6ohm that way you can run them easily at 4ohms or 1ohm. As for amps there are many many amps that will suit your needs. The kicker will be too much power for those and neither of them are stable at 1 ohm and dont put out enough power at 4. Ok forget what I just said I didnt see that you are going with only two of them now my bad. lol! I would get dual 2ohm run them at 2ohms with a JBL 600.1 or a Kicker 600.1 they will sound nice. |
Post Number: 120 Registered: Jun-04
| Posted on Tuesday, February 15, 2005 - 12:44 pm: |
James ive come to the final conclusion but i need your help as to what ohm subs i could should get but im defintely getting the w3v2s and a jl 500/1 but what ohs subs dual 2 or 4 |
Wilton,
Ct
Post Number: 718 Registered: Dec-04
| Posted on Tuesday, February 15, 2005 - 01:03 pm: |
dual 2. http://jlaudio.com/tutorials/wiring/index.html#2dvcsp |
Post Number: 122 Registered: Jun-04
| Posted on Tuesday, February 15, 2005 - 07:34 pm: |
so the dual two ohm subs will give me the maximum wattage outof the amp to the subs correct cuz itlll b a 1 ohm load? |
Wilton,
Ct
Post Number: 725 Registered: Dec-04
| Posted on Tuesday, February 15, 2005 - 09:16 pm: |
no a 2 ohm load run them in Series / Parallel.
Post Number: 123 Registered: Jun-04
| Posted on Wednesday, February 16, 2005 - 04:19 pm: |
how do u think this will sound james in a focus hatch... im guessing pretty loud and clean |
Wilton,
Ct
Post Number: 772 Registered: Dec-04
| Posted on Wednesday, February 16, 2005 - 06:37 pm: |
yeah man it will sound nice! |
