Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > Woofers in the box?
Author Thread: Woofers in the box?
Username: Mladen
I was thinking of puting two 8" woofers (not subwoofers) 90W nominal power in the box in the trunck. Does it make any sence?
How should the box look like?
Username: Joebruce
KY
U.S.A.
Post Number: 62
What do you meen "woofers not subwoofers" they are the same thing.What kind of "woofers" are they?What kind of amp?You will need to get a head unit,amp,all the wires berfore you should worry about the box.If you want to go with 8s i would go with 2 jl 8w7s they are kinda expinsive tho.
Username: Mladen
I allready have those speakers 2x signat h-20, 8"speakers, but they are not subwoofers, just speakers (smaler magnet, less power...)
They are:
H 20
Type Component woofer set
System size: 200 mm
Membrane: injection carbon polypropylene
Surround: Butyl rubber
Basket: SIGNAT blue steel
Gasket: Plastic
Magnet: Barium (17 Oz) 100x60x20 mmm
Voice coil: 36,0mm
Terminal: 2,8x0,8mm 4,8x0,8mm Gold Plated
Technical data:
Music power: 2x180W
Nom. power: 2x90W
Nom. impendance: 4 Ohm
DC resistance: 3.6 Ohm +/-15%
Frequency response (MSPL-10 dB): 40 Hz - 5 kHz
Recommended frequency range: 40 - 2 kHz or full range
Free air resonance frequency: 45 Hz, +/-20%
Mean sound/ pressure level: 88.5 dB/W/m, +/- 3dB
Qts: 0,8
Vas: 40,0 ltr
Xmax: 3,35mm
Mounting diameter: 183mm
Mounting depth: 84mm
As for the amp I was thinking of buying alpine MRP-F240 or Audiobahn A6004T, what do you think?
Heeeeelp.... thanx
Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > Woofers in the box? [ « Previous ] [ Next » ]
