Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > Alpine M301? M501? or Audiobahn A8000T
Author Thread: Alpine M301? M501? or Audiobahn A8000T
hey guys
which of thoese amplifiers are better for a kicker L7 or rockford fosgate T1(still dont knwo what sub to get)?
Alpine M301
Alpine M501
Audiobahn A8000T
also, the audiobahn is rated at 800w rms and the alpines are 350 and 550 rms. i hear the aplines are underrated but i dont know what that means.
is 800w with the audiobahn a lot better than 550 with an apline or are they pretty much the same?
Username: Rzarector
Coquitlam, Bc
Post Number: 209
the 350 will put about 400 amps and the 550 about 600 dunno what those subs are rated but match them up i guess
Username: Carguy
Post Number: 1515
If you're on a tight budget, then I'd go with A8000T. Alpine amps are overrated to me. They rely too heavily on their name. Check the specs on those amps, nothing special at all.
You might want to go with PPI's PC or PCX series instead. They are slightly higher in price but will sound much better.
Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > Alpine M301? M501? or Audiobahn A8000T [ « Previous ] [ Next » ]
