Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > How many RCA Y-connectors?
Author Thread: How many RCA Y-connectors?
Username: Bigclevdogg
I am going to hook up mulitple amps. I found on crutchfield that you can use y-connectors to do this. Can I hook up 3 to the one on the deck without losing quality?
oh yeah also what about the remote wires?
Username: Carguy
Post Number: 1495
Just how many amps are you talking about? You have to consider your existing power wires. With increase in amp quantity, it will draw more power from your car. So you might need thicker wires.
Most amps will have a pass thru rca output jacks, use those along with the y splitter.
With every split, you will lose some, but nothing that you will notice.
Username: James1115
Wilton, Ct
Post Number: 603
Isaac is right about the power and Rca's. As for remote wires you can just jump them from amp to amp. or run back as many as you want.
Hey Isaac I got the response from Ron and everything is a go so thanks alot.
Username: Carguy
Post Number: 1497
Glad everything worked out. If you have any question you can give him a call. Mid morning is the best time to reach him. I think he works the night shift.
Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > How many RCA Y-connectors? [ « Previous ] [ Next » ]
