Thread: Distortion Problem |
TrevorS Unregistered guest |
| Posted on Friday, February 11, 2005 - 04:48 am: |
I have a pioneer deck with a sony xm-752x amp (2 channels) and some cheap subs from Circuit City. When i have the balance on the deck centered it distorts very bad at mid volume. If I move the balance to the left or right the one sub its balanced on sounds great. Second if i bridge the amp the both subs sounds alright but if the amp is turned to high it keeps going into protection mode. Any help would be great!!!! Thanks |
Gold Member Username: Carguy
Post Number: 1488 Registered: Nov-04
| Posted on Friday, February 11, 2005 - 09:55 am: |
Well you have 2 problem. Sony amp and cheap subs. They are not a good combo. Anyhow, check your gain/level setting. If it's not set properly, it'll force the amp to go in protection mode and cause distortion.
| Posted on Friday, February 11, 2005 - 10:41 am: |
Make sure that when you bridge your amp and wire your subs that you're not giving it a lower ohm than what its rated for. remember, that when bridged, the amp runs at 4 ohms. |
| Posted on Friday, February 11, 2005 - 01:06 pm: |
I have checked all that. If I have the amp set more then 1/2 it will go into protection mode. So for now I just have it set at half. I havnt had the amp hooked up for a long time but it worked fine when i took it out. And I thought if anything would make it sound like crap would be bridgeing it, not running it as 1 channel per speaker. And I dont understand why it would sound so good with the balance to the left or to the right.
| Posted on Friday, February 11, 2005 - 01:37 pm: |
could one sub be out of phase, (crossed the pos, neg wires.) and when both of them are moving, they are canceling each other out thus creating distortion. that may be why it sounds good with only one sub playing and bad when both subs are playing. |
| Posted on Friday, February 11, 2005 - 01:39 pm: |
and as for your gain setting, it should be set at the voltage your amp signal is. (ie. 4volt preout HU, amp gain set at 4v) |
| Posted on Friday, February 11, 2005 - 03:07 pm: |
Could you set me straight on the gain part please. I thought it meant the output settings to the subs. I will go check out the wireing and get back to you. Thank you for you help!!!!! |
| Posted on Friday, February 11, 2005 - 03:45 pm: |
Ok now I feel like a dumb @#%. I Should have checked the wireing first. Had the polarity reversed on the passenger side, at the box. I didn't relize it would make that much difference. Anonymous, I do appreciate all your help and suggestions. Thank you soooo much!!!!!! |
| Posted on Friday, February 11, 2005 - 08:20 pm: |
you can search this forum about gains levels. alot of people are misleaded about the gain settings. |
