Thread: NEED HELP with my amp |
| Posted on Friday, February 11, 2005 - 02:15 am: |
I am having trouble seeing what goes to what, the things I need help in is in the picture http://pic17.picturetrail.com/VOL809/3228131/6595604/84918253.jpg |
Gold Member Username: Carguy
Post Number: 1485 Registered: Nov-04
| Posted on Friday, February 11, 2005 - 09:33 am: |
Your picture is too dark. Hard to make out. Anyways, if you start from the left and count, you'll see that each channel gets 2 connectors, one for pos and neg. So now if you look at rear right channel, you'll notice that neg and pos are slightly off towards the right. The next connector is the REM (remote wire), then GND for ground, and finally VCC for your positive power from battery. VCC = Positive supply voltage. |
