Thread: This is odd |
| Posted on Friday, February 11, 2005 - 01:07 am: |
Sometimes when my 12s are bumping good the protection light comes on but they are not bumpin to hard i.e bottoming out etc. All i have to do is go into the back grab the box and shake the car wit it a bit and it goes back off protection and works just fine. Its the weirdest thing. Any ideas of what this is? Im thinkin its a bad ground or a bad power supply in the amp? I dont know any ideas would be great. |
Silver Member Username: Hdubb
Farmington,
Nm
Usa
Post Number: 640 Registered: Nov-04
| Posted on Friday, February 11, 2005 - 01:23 am: |
the load on the amp might be too low. what do yu have it wired down to in ohms? or it could be a loose ground |
| Posted on Friday, February 11, 2005 - 10:58 am: |
loose ground possible the subs are parallel to 4 ohms i know its not that. |
Silver Member Username: James1115
Wilton,
Ct
Post Number: 597 Registered: Dec-04
| Posted on Friday, February 11, 2005 - 11:25 am: |
pos + neg could be touching inside the box. Its doubtfull but could happen. |
New member Username: Brett99
Post Number: 3 Registered: Feb-05
| Posted on Friday, February 11, 2005 - 04:11 pm: |
Is it getting really hot I had an amp wired to what was suppose to be it's proper load but after full volume for 45 min it would shutdown. How long will the play and what class of amp is it? |
| Posted on Saturday, February 12, 2005 - 02:40 am: |
the amp is not gettin very hot at all. its random how long it will play. I dont know what class amp it is it is a Audiobahn A8002t |
