Thread: Will a car amp work on my PC??? |
New member Username: Julio_u
Post Number: 1 Registered: 02-2004
| Posted on Friday, February 13, 2004 - 04:56 pm: |
I was wondering if anyone can help me out. I have a KENWOOD KAC-929 2 channel 1000w max power AMP, 2 10" TS-W254C PIONEER SUBS, each at 250w RMS and a pair of INFINITI 652i 6.5" speakers. All this I want to have as my audio system for my computer, but don't even know where to start. At the momment all I have is an onboard Sound card, but a newer one can be bought once I know where to start and what to look for. If anyone can help me out it would be much appriciated. Thanks |
Post Number: 1168 Registered: 12-2003
| Posted on Friday, February 13, 2004 - 08:11 pm: |
your best bet is just to buy a set of PC speakers, like the Logitech Z680 system. there is no good way to do what you want, without spending several hundred dollars on a power supply/rectifier, and even then, it'll honestly sound lousy. Car audio gear isn't meant to be used in a large room, and it never sounds good in such a setting.
Bronze Member Username: Bass_lover
Post Number: 14 Registered: 01-2004
| Posted on Saturday, February 14, 2004 - 02:32 am: |
If you do want to spend the money buy a 25amp power supply, this one is suited for your needs and is only $99.00 click here for the power supply Hook everything up as you would in a car exept wire your remote to the +12v terminal to turn it on.On your pc's sound card there should be an output that usually goes to a pair of speakers,click here for the plugLet me know how ya go. |
