Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > Elemental Designs and JBL
Author Thread: Elemental Designs and JBL
Username: Xxkmfdmxx
St. Petersburg, FL
Post Number: 312
I just purchased two Elemental Designs 13Kv.2 Dual 2 ohm subs, Was wondering if a JBL 600.1 amp would be good enough for them?
Username: Carguy
Post Number: 1454
You'll need 1000w rms amp. Try JBL's 1000w model, JL 1000.1, Orion, and PPI.
Username: Xxkmfdmxx
St. Petersburg, FL
Post Number: 313
..There 350W rms though the 13kv.2's. why 1000 rms? Thinking of the OV.2's maybe? Their 600w RMS each. IF I wire the subs to 2 ohms The Jbl should put out atleast 600w(Someone told me it could put out upto 800w at 2 ohms but dont know if thats true)
Username: Carguy
Post Number: 1461
Oh ok, I thought they were 600w rms. In that case JBL 600.1 amp will do just fine.
Username: Help_2
Post Number: 56
You can put 500w on one 13Kv2 no problem...
Theyll sound just fine on a 600.1, although
you might want to consider a larger amp.
Username: Xxkmfdmxx
St. Petersburg, FL
Post Number: 314
Yeah, Maybe sometime in the future, I was just getting the JBL amp at such a great price, Figured I'd get it.
Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > Elemental Designs and JBL [ « Previous ] [ Next » ]
