Thread: Choosing a system...so lost |
| Posted on Wednesday, February 09, 2005 - 04:26 pm: |
alright, my stock stereo system in my car has zero bass and an upgrade is essential i wanna spend 150-200 max for the amp i wanna spend 80-130 max for 1 or 2 subs ive seen so many things but i hav no idea what brands are good and whats not what is the best system i can compose with my price range also, do the wires you hook up the amp with affect the sound of the bass and effectiveness of the amp?? |
Bronze Member Username: Marley289
Post Number: 86 Registered: Nov-04
| Posted on Wednesday, February 09, 2005 - 05:20 pm: |
here try this, im a big mtx fan and this will definatly put some bass into your system and fit your price range. amp - http://www.millionbuy.com/mtxthunder311d.html subs (get 2) - http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13310 i have this setup and i couldnt be happier with it. you could even have a little extra to spend on a box (1.25 cubic feet, sealed), wiring kit, and rca's. |
Bronze Member Username: Audio_fanatic
Mukilteo,
Wa
Post Number: 31 Registered: Jan-05
| Posted on Wednesday, February 09, 2005 - 08:23 pm: |
I wouldnt recommend those subs, IMO those are terrible subs, i would instead get one adire shiva, around 125 then get tha appropriate amp to match it. |
