Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > How loud would a jl 500/1 and 12w7 co...
Author Thread: How loud would a jl 500/1 and 12w7 combo would be?
Username: Adriand619
San diego, Ca
U.s
i have a jl audio 500/1 amp and i am planning to buy a 12w7 but i dont know if it will be loud enough for me.i previously owned a 15 KICKER L5 AND WAS HOPING THAT MY 500/1 AND 12W7 WILL BUMP HARDER THAN THE KICKER. ALSO,WILL THE 500/1 MATCH PERFECT FOR THE 12 W7.SO CAN ANYONE GIVE SOME GOOD INFORMATION ABOUT THAT PLEASE.THanks
Username: Shouder
Wisconsin
Post Number: 100
That 500/1 may not be enough for your 12w7. I don't think you would be too happy with the w7's performance it you powered it with only 500watts. The 12w7 is optimum around 700-800watts. At that range im sure you would be very pleased.
Username: Jessez92987
i have the JL 500/1 amp with 2 12w3 and personally i love the way it sounds
Username: Jonathan_f
GA
Post Number: 3186
The 500/1 matches the 12W7 very well, the 500/1 is very underrated. In a sealed box you'll typicaly reach close to full excursion with it. It should get louder than that L5 was, and sound a lot better doing it.
Home > Message Board > Car Audio > Amplifiers > Archive through February 15, 2005 > How loud would a jl 500/1 and 12w7 co... [ « Previous ] [ Next » ]
