Thread: Can 4-channel support 4 -speakers and a modertae subwoofer? |
Rambabu Unregistered guest |
| Posted on Tuesday, February 08, 2005 - 05:03 pm: |
I have 100 X 4 RMS 4- channel amp and it is tri-way capable, using this tri-way capability can i power a moderate subwoofer (100 RMS), my front speakers are only 60 RMS, can i draw some power from front-channels. Goal: is to power all 4-speakers and a little sub-woofer Thanks |
Gold Member Username: Carguy
Post Number: 1450 Registered: Nov-04
| Posted on Wednesday, February 09, 2005 - 06:23 pm: |
Yes you can. 4 channel amp can be used as 5 way. 2 channels for the front, 2 for the rear, and rear channel bridged for the sub. All you'll need is couple of capacitors for the rears and a coil for the sub.
| Posted on Wednesday, February 09, 2005 - 06:50 pm: |
Issac, Thanks for the reply What is a coil? Can i use a tri-way crossover instead of capacitors and coil such as the following one http://www.crutchfield.com/S-W4XfFMfctic/cgi-bin/ProdView.asp?i=127TM100
Post Number: 1460 Registered: Nov-04
| Posted on Wednesday, February 09, 2005 - 09:05 pm: |
Yes you can use that device. It's the same as getting 2 capacitors for the rears and a coil (used to filter out high freq for the sub). |
