Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > P5002 Fosgate amp/subs wiring question
Author Thread: P5002 Fosgate amp/subs wiring question
I have 2 Fosgate Punch Stage 2 Subwoofers rated at 200W RMS and 400W Max with a P5002 Fosgate Amp 125x2 @ 4 ohms and 250x2 @ 2 ohms.... how would I connect them to the amp without making it 2ohm bridged, which would mess up the amp... if I wire them in parallel I'll only be able to wire them to either the left or right channel... yet if I bridge them and connect them in mono I'll have 500Wx1 @ 2ohms which the amp isnt made for... since it'll be both parallel and bridged at the same time...
Anyone have any ideas as to how I would wire my subs to get 250W to each sub or perhaps a mono bridged diagram that would keep the amp at 4 ohms while still connecting both subs at once
Appreciate it
Username: Taylor17
Kopperl, Texas
Post Number: 395
First, what ohms are your subs?
each sub is 4 ohm single voice coil
Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > P5002 Fosgate amp/subs wiring question [ « Previous ] [ Next » ]
