Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Will a 1400 watt amp kit bring down w...
Author Thread: Will a 1400 watt amp kit bring down watts in a 2000 watt amp?
question
I have a 2000 watt amp and I was looking at amp wiring kits. The ones I saw were only 1400 watt kits. Will that kit bring down the watts in my amp
Username: James1115
Wilton, Ct
Post Number: 568
That depends on the make and model of your 2000 watt amp. If it is Sony then you have nothing to worry about but if it is Zapco,PPI,Orion,US amps,Arc Audio,Tru Tech,ECT...... you will not get full power out of your system not to mention melt your wires possably causing a fire on the way.
Username: Solacedagony
New Jersey
US
Post Number: 259
For that much power, you're definately needing to run 0/1 gauge wire.
Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Will a 1400 watt amp kit bring down w... [ « Previous ] [ Next » ]
